BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Thu Aug 25, 2016 7:22 pm
Back in the day taking the Cats off was a great way to get more power, but newer cars not so much. If they are shot and you don't have to pass a smog test in Indiana then what the heck, do it. They used to make these little parts called "Test Tubes" which were essentially made to replace the cat converter to "test" if it was bad..which was the easy way to get rid of the old style POS cat converters. If you don't need to pass smog that might be the easy way out, if you do then start shopping for replacement converters.
