I just wanted to talk about oil changes. I change the oil on my '14 QX80 every 2000-2500 miles because I don't drive it much. It usually takes about four months to reach that mileage.
I have been using Castrol Magnatec 5w-30 and Bosch 3233 oil filters. Anyway, I kind of wish the newer engines were not direct injection, because this system puts a lot of soot in the oil rather quickly. Valve buildup and other problems related to direct injection probably won't matter to most owners, but I like to keep vehicles for a long time (I have a 2002 Chevy truck with 376k miles).
I will probably have a lot more problems out of the transmission before I do the engine, considering it is a sealed transmission with "lifetime fluid." It really irritates me that this vehicle does not have a transmission dipstick. On my Chevy I can simply suck 4 quarts out out of the transmission dipstick tube and pour fresh fluid in every several thousand miles. This process is extremely simple, and you know there is clean fluid in your transmission.
