caster asjustment?
turbo2nr
Car: 97 240sx (kouki)
recently did my alignment on my s14, i have megan coils and im slammed, i thought my camber on my pass. side wheel was off because of bad tire wear and the wheel was more sunked in then my driver side.
turned out that the camber was good but the caster on my passenger side is off my 2degrees.
driver side 7deg caster pass side 5deg caster
i believe 7degres is about right for our car b/c on the hunter rack it was in the green.
how do i adjust for caster? what do i need to do to correct this?
ashibah83
Car: 93 SUPA BLACK COUPE
adjustable tension rods.....
you should want about 6.5 degrees on the driver side and about 7 degrees on the passenger side
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
ashibah83 wrote:adjustable tension rods.....
exactly...I am getting ready to put my coilovers, tension rods, toe arms, rucas, and traction rods, this may sound stupid but how do I know what spec is as stated above...threadjack complete
Koshin
turbo2nr
make ya own thead!lol j/k its on the hunter aligment rack..
ok tnx imma install my adj. tc rods
