to adjust for 240sx: camber plates or camber boltscrookedcop7 wrote:camber is angle of the wheel up and down
to adjust for 240sx: adjustable tie rodscrookedcop7 wrote:toe is the angle of the wheel in and out
to adjust for 240sx: adjustable tension control rodscrookedcop7 wrote:caster is the angle of the wheel side to side
I really wouldn't worry about your caster problem. Your car is still in spec, and right and left are close. Honestly, even after getting adjustable arms, and getting them set equally, you will never be able to tell the difference.Bosrudorfer wrote:I have the same problem. Here is a picture of my alignment printout if it will help you out. As you can see my right is off by ".6". And yes tension rods will fix this problem, I will be ordering some SPL V2 tension rods which seem to be the cheapest I have seen at $169. Still deciding on which color to get though... LOL
BTW if you had searched you would have found my same topic thread I posted 2 weeks ago. zerothread?id=147747
