cast iron vs. stainless steel
TY_DOHC91
Car: 1991 240SX KA24DE
what is a more desirable turbo manifold
cast iron or stainless
pros and cons
Structure240sx
cast iron is much more durable, stainless looks nice and would be a little lighter
TY_DOHC91
where would one find a good cast iron onefor a ka24de t3/t4 application
bang for buck
Structure240sx
look for the revhard manifold. thats what i have
TY_DOHC91
DOES THE MANIFOLD DIFFER BETWEEN S13 AND S14
OR WILL ANY KA24D MANIFOLD FIT
NX95240
Car: my KA-(sc61)
i have a ETD mani. and like it . we had a group buy and theres a few of us here that have it.
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
call me special but i've managed to put 5 cracks in my REVHARD manifold, however it has over 30K miles on it. damn i need to find another one on ebay.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
^^^ Did you slot betwen the runners and expand the bolt holes?
(I did, and have had ZERO trouble from it...with ~15,000 miles of abuse.)
??? - Brian
( PS: Did you get that ECU...? )
TY_DOHC91
slot between the runners?
are you refering to cutting the flange
how does that contribute to prolonged durability?
:: orion ::
Allows expansion of the individual runners...same goes for opening up the bolt holes. When you get a RevHard, it barely slides over the exhaust manifold studs...so when it goes to expand, it has nowhere to go...so it cracks. Open the bolt holes, slot the flange between the runners...and everything can expand and contract a little, so less chance of cracks.
The more room you aloow for expansion, the longer it will last.
- Brian
Structure240sx
exactly what :: orion :: said. i cut the flange between the runners, drilled out the bolt holes, and also ported out the ports (they are centered perfectly with the head ports). i've had my revhard on for over a year and 17k miles also with zero problems
S14tat
Car: 2007 FX35
1994 Acura NSX
ahhh ic, on my next manifold i will do that. and yes orion i recieved the ECU on tuesday. do you guys know of a place that sells the manifolds for a better price?
Structure240sx
looks around ebay and the forums. they go for anywhere from $250-350.
