caspers_240 »
https://forums.nicoclub.com/caspers-240-u36050.html
Sun Nov 15, 2009 6:13 pm
Next up is the timing chain assembly:
I lube everything. The first KA I built, I listened to a guy that told me not to use Moly that engine oil was enough. Well, he was wrong. It gaulded the s*** out of everything on the head... May work for SBC's, but not the KA.
I try not to get carried away with it b/c it WILL clog up your oil filter if you don't change it after the car has run its first 15 min or so. Wipe off any excess too. I like to mix oil and Moly so I don't have to use so much of the thick stuff.
Back to the build:I just built the motor about a year ago. When I did it the first time, I had the head decked and I lapped the valves in good, so that's taken car of. I also re shimmed everything to spec. I took everything apart for cleaning and re-oiling b4 reinstallation.
I like to put a little molly on top of the valves, and oil the springs really good b4 I put the buckets and shims back in.
Cams are cleaned, checked, lubed and installed...Yes, they're stock... I fail.
These chains, guides, and tensioners are OEM Nissan and only about 1 year old, so they just get cleaned up and put back into action. The way I did this is against FSM, BUT; this is the way I like to do it so I can be sure that something doesn't happen and the bottom chain gets off by 1 tooth. Set the #1 to TDC of course...
I like to put everything together at this point and then go back and TQ the cams and timing stuff last and at one time so I KNOW I didn't miss anything.===================================================================================================
Next is the front cover and oil pump. Gotta take it apart, clean and inspect the pump gears or whatever you want to call them. Most people put Petrolum Jelly in here by the gobs but I feel like that will clog up the oil filter. So I pack it with moly, (I did my own test and the Moly is thick enough to prime the system, but will go thru the paper filter better than the jelly) it may not be the best way, but its what I feel is best.
And this is the current state of the motor.
