Z-owned »
https://forums.nicoclub.com/z-owned-u104848.html
Thu Jun 13, 2013 4:57 pm
a little white out on the 15 degree btdc and on the pully timing mark make things alot easier. Otherwise a timing light connected to cylinder 1 is what you need with the car warmed up. In general the cas should be sitting around the middle of it's range of motion, if it's to far one way or the other it's generally a sign of the timing belt being off even if the car reads 15 btdc
