minlow88 »
https://forums.nicoclub.com/minlow88-u168432.html
Sun Jan 06, 2013 3:47 pm
I just changed the timing belt, as well as bearings because one was squeaking,I did not Change the tensioner, I have done many timing belts, an I am possitive I am not a tooth off, turned the motor by hand at least 10 times and the marks were lined up every time. made sure it was dead on before putting it all back together.
15*btdc, engine pulses while accelerating, idles rough, adjusting at screw on iac raises and lowers the s*** idle.
I did several test drives after adjusting timing and tps an idle, advancing it 2* each run.
At 21* right now and have the smoothest idle, whether I baby it, drive mild, or hammer the s*** out of it, it accelerates just as smooth and sounds beautiful and actually goes.
Also inspected my plugs after each little drive and it is getting a clean burn .
So no offense mrmoose but I do not believe that 15* is spec for an N/A, but I could be wrong.
Edit** I did find the sticker Under the hood, and it does say ignition timing 15*
