CAS Serie 2 on Serie 1 RB25det
Supextaz
Car: R33GTST
hi, i've just bought poncam serie 2 with cas serie 2 but i have a serie 1
i want to know if it's possible to work in good condition
i think i have to modify the wiring..
(sorry for my bad english i'm french ^^)
so i need help ^^
thanks very much
Carl H
depends on what cam angle sensor you have, if you have a normal silver cas then it should be fine.
post a pic of the cas you have and a pic of the inside of the exhaust cam snout.
RRRRB
Car: 98 RB powered S14
Poncam series 2 is for R34 neo motors.. what's the camshafts part number?
Supextaz
Car: R33GTST
it was a metal cas, but now i have poncam serie 2 RB25 (R33) and i have a plastic cas. i want to know if the wiring is same.
i have read that could be 1-4 2-3 to 4-1 3-2 to work in good condition, that's good?
Carl H
i think the power and grounds are the same but the outputs are flipped on the plastic cas.
as long as the cams are for a late series 2 r33 motor then they will work, if they're for a neo then they will not work due to the hydrolifters in the head where the neo is solid.
RRRRB
When Tomei refers to "series 2" with their cams they are referring to the R34 NEO motors.. i found this out the hard way.. R33 series 1 and 2 are the same. just a heads up
Supextaz
Car: R33GTST
so there is no problem. i just have to re wiring the S2 cas no?
