CAS sensor
Duke51
Car: 1990 nissan 300zx na
okay so figured out why i can't get my 1990 nissan 300zx started, it has bad spark plugs. but in narrowing down the search to find the problem (i used a service manual) it had me go through and test some other stuff, in the process it had me take off the C.A.S before doing so however i marked where it was positioned then i took it off to test the injectors by turning it. i then proceeded to reinsert the C.A.S and lined it up with the marks i had made. so here's my question is that fine or do i need to re-adjust it? if so how? because the service manual oddly enough does not say anything about adjusting it just says to put it back on. Thanks.
oh and is this the right chat to be posting these kind of question on or is there a better one? thanks
WDRacing
If you installed it back in the same place you marked it you should be fine. If you have more 300zx questions try our 300ZX Tech Forum.
If no one else has said so, welcome to NICO.
WD
Duke51
okay sounds good! and thank you!
NolimitZ32
Check with a timing light just to be sure.
