b00stinbmx »
https://forums.nicoclub.com/b00stinbmx-u122913.html
Fri Jul 30, 2010 4:42 pm
So i've had my car running pretty damn good for the last few months. Its just a basic Rb25det s2 in a s13 hatch. I did all the wiring and everything works fine. Never had a problem with it till now. I was about 1/2 mile from my house and the car starting bucking like it was a boost leak. when i came to a stop the car stalled, was hard to get it to fire back up but it did. then it died one last time and nothing. I check everything out when i got it home. Fuel pump was working and i had pressure. Had spark, cleaned the MAF. also unplugged it and tried to start it in limp mode but nothing. I went through the entire harness to see if anything had unplugged but sure enough it all looked good. Lastly i pulled out the CAS and with the car on spun the cas, it would click once and the fuel pump would turn on and continue to run as long as you kept spinning it but you couldn;t hear any injectors click like they normally do. once you stopped spinning it and did it again it would be the same thing, click once and run the fuel pump. SO im 99% sure its a bad CAS but i don;t really get why it would just s*** out on me like that. Would like some input from you guys before i go ordering anew one. thanks! need to get this s*** back on the road for some clubloose and d-faction events!
