cas question
J240sx
Car: 89 240sx
So it was finally time for me to attempt to start my swap that i just finished. It cranked but didnt start so I decided to check my cas first. So i ended up taking off the wrong screws and basically taking the cap off and unscrewing the metal disk. I didnt pay to much attention to how it looked when I took it apart besides that I think it was 3 screws and the metal disc. Im not sure i put it back together the correct way so i was wondering if anyone had any pictures on how it should look or go. I checked the fsm and didnt find any useful pictures unless i somehow skipped over it. I never actually took the whole cas out, just the screws and the metal plate. I also plan on checking to see if im getting spark and fuel later today. Thanks for any help.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
The wheel is notched so it will only go on one way.
Justin35ll
Car: s13 coupe sr20det
Should have checked for fuel and spark first? Let us know after you check that
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
The cover on this SR CAS is busted but everything underneath is intact so I hope it helps you.
J240sx
Car: 89 240sx
Thank you my good man! I will go check everything out tom and report back to you all with the news. Thanks again.
