elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Jul 22, 2006 4:46 pm
Here is the way to check the CAS, this is for a 94... If you have a 90-93 it may be sligtly different (as youd have to probe the sub cas harness for the 90 degree signal and the main cas harness for 1 degree signal)
Long story short, its in AC, 100mV. The CAS singal for 90-93 and 94-96 is the same, but the harness is different.
