correcto!Cyberkreig wrote:I'm going to try to space out dots.. it may or may not work.
I think you mean your CAS is like this:
Instead of like this:
as pictured in the FSM.
Regardless of the lineup. Align the right most mark with the "mating mark" on the cas Typicaly in the 12 o'clock position. As you slide the cas into position the left most mark should rotate up and line up with the mating mark, again 12 o'clock.
At least thats how i did mine, then do the small adjustment with a timing light.
