Sileighty_85 »
https://forums.nicoclub.com/sileighty-85-u124820.html
Fri Jan 30, 2009 9:53 am
Everything thing but the CAS is Correct you need to rotate the CAS Counter Clockwise to look like this
When you slide it in you want it to line up on the LEFT DOT
So to do that pull it out line it up on the RIGHT Dot and side it in the it should rotate to the LEFT Dot
And once done properly ajust it so that the right side adj bolt sits around in this area it will put you pretty close to 15* if not on it.
Modified by Sileighty_85 at 12:05 PM 1/30/2009
