According to the FSM, the CAS sensor electronics get their power supply (+12V, ground) from the harness connector. Any idea why the sensor housing would need a separate good ground as well?float_6969 wrote:Yea, if that fixed the issue, you have grounding issues.
That's just too much current. That sounds like a short. But I'm completely baffled as to how the CAS housing gets to 8.1 volts normally (since both CAS's are doing this), when the CAS itself is only connected to the car's electrical system via the CAS connector. The only thing I can think of, is that maybe the CAS housing and the sensor ground are connected internally from the factory AND there is a miswiring or damaged wiring /insulation somewhere. I'm away from my car and spare CAS, so I can't test the former... the weekend soonest.chalander wrote:Quick update, I tried my second CAS and it shared the same symptoms. I measured the amps flowing from the CAS to my intake mani and it measured 1.1 amps and 8.1volts - as soon as I touched the CAS unit to the intake mani both reading went to 0 because the CAS was then grounded (fuel pump primes).
What do you know about your car's CA conversion history, with regards to wiring? Did you buy it like it is?chalander wrote:One earlier comment that caught my attention was that my ecu may be resetting itself when the CAS becomes physically grounded. I observed my ecu lights when I grounded the CAS unit, the fuel pump primed as I described earlier but I noticed that for the amount of time that the pump was priming the ecu red light would turn off then once priming stopped it would turn back on, the green light remained on consistently. When I turned my ignition from the off to on position both ecu lights came on and stayed on during and after the fuel pump priming.
I have checked the blue ecu plug wiring, the dash plug wiring, majority of engine grounds that I could find both visually and via the FSM. The only somewhat bad ground I could find was the one for my starter, it is only half intact where the wire meets the clip, I will be redoing this tomorrow, but doubt it will provide any results.
Also I tried disconnecting my igniter and drop resistor to see if the CAS amp measurement would differ, but it didn't.
I also noticed that the voltage across the battery terminals would drop from 12.3 to 11.3 when I toggled the ignition from off to on. ( the voltage is a bit low for my battery but I has the ignition on for quite some time while troubleshooting so it probably drained the battery a bit, the battery is only a year old and tested good at a shop 3-4 months ago)
