sonomasophie »
https://forums.nicoclub.com/sonomasophie-u313960.html
Sun Nov 10, 2024 5:07 pm
hi, my name is sophie I have a 1993 300zx. I bought it about a year ago, not running. It hasn’t run in from five years to over a decade, unsure exactly when it last ran not the most knowledgeable in cars specially, the electrical side of things the car has a strong crank, but will not start. I have replaced the coil packs, spark plugs, PTU, oil filter, drained the old fuel and added new fuel and did an oil change. i was told by a friend that the ptu was the problem. so i replaced it and no change. i was told by someone else that my cas is getting no voltage so i was told to buy a new one. i did and have not installed it because im not sure what the right voltage is. very confused on the whole thing. am i supposed to measure in ohms or mv or volts and what should the right reading be if this was the issue? also could someone tell me what the trouble shoot lining should be? spark is definitely the issue so if it’s not the coil packs, the spark plugs, the ptu, or the cas (if nothing changes), then what is the next step? the ecu? looking for anybody to help!
