JonPowell »
https://forums.nicoclub.com/jonpowell-u5113.html
Sat Jun 28, 2003 9:54 am
I would also try pulling a spark plug and seeing if you get spark. Check for fuel pressure also, are your fuel lines hooked up correctly? the feed goes to the rear of the fuel rail and the return is up front near the regulator. Try turning the CAS by hand and listening, if the injectors are working you will hear them fire. You can also put the ECU into diagnostics mode(not sure how, depends on your year and model). It will tell you if the CAS is ok or not. Check megalla's website for help on diagnostics.
