donjuanmon »
https://forums.nicoclub.com/donjuanmon-u30515.html
Wed Feb 04, 2009 1:55 pm
Hey Bored, I actually had a similar problem in the past where my ride overheated. I changed the radiator, water pump, thermostat, and still nothing was fixed, the fan was operating as it should, no head gasket damage and then one day I did use the fix a leak "bull ****" that you referred to and amazingly it fixed the problem for me and 8 months later it still runs like a champ. I'm glad it worked because I wasn't looking forward to replacing the motor at the time or doing a rebuild.
As for rbeast, I hope your problem gets solved. My gauge definitely went all the way up when I had problems. I'm not a mechanic but I'm guessing that it could be an ecu or electrical based issue if none of the normal methods work. I doubt it though. What do you guys think? Whatever it is I hope you get it solved. I remember being in the same boat.
