cars gone nutz please help
dsc4130
im in the middle of an rb20 swap and i was trying to hook up my boost ,a/f gauge and my turbo timer when i ran into some problems. when i turn on the headlights the gauge cluster wont come on and the raido shuts off but when i turn off the headlights the radio comes back on. then i went to unplug the radio and the windsheld wipers start up. and heres the fun part when i turn the h/l on the tach goes up to 2k rpms. wtf is going on???????????
oh and im doing an auto to manual swap at the same time
benemorius
Car: s13, s13, eg, e36
Check fuses first. Crazy things can happen when a fuse goes out.
Had you actually gotten so far as hooking anything up yet or....?
dsc4130
ive gotten most if not all of the rb harness hooked up. i need the ignitor and it will be done. and the turbo timer but idk were to wire the boost gauge to and idk which wire to wire the a/f gauge to. 3 wire 02 sensor. thats about it. ill check in the moring.anyother ideas????
neverlift
are you stealing power from the radio supply? I had some probs. with my efan and a/f gauge when ran off the radio supply. Simple fix all I did was put a 10amp higher fuse. But that was my case.
