WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Mon Aug 01, 2005 1:17 pm
After fixing the multiple 240 Gremlins I had under the hood, I made 5 15 psi pulls with no problems. I'm running out of fuel at 15 psi at 6000 or so RPM. So the stock S14 fuel pump is good for about 14psi then she sputters out. Which is about as good as the R32 Skyline pump. They are probably the same part.
So anyhow, I need a bit of fine tuning and ton of cleanup. The under hood area looks like a grenade went off. So I'll be wrapping everything and doing some paint/polish work, then you guys will get about a gig worth of pictures to look at. Hopefully this will include my Alky kit and IC sprayer.
1.8 years and 4-5 thousand in parts and pieces...but she's fun to drive. Never give up your project. Not many people can say they built an entire turbo kit from scratch and it works pretty damn good. But I am finally one of those people.
