Cars dies out after cold starts
GuSpeed
When I start my car in the morning when the engine is cold, it would stall out and the rpm drops low and then goes up to normal until its warm.
NISTECH
coolant temp sensor? Fast idle control problem?
Biggs2004
Car: 2001 Hyundai XG300
lol, I mean this in no way to be taken like I'm a smart aleck, but how long has it been since you've had a tune up? I mean a good thorough tune up. Just a suggestion.:)
yozsi
Car: Racing
sounds like you idle controller.
GuSpeed
thanks.. I just bought the car so haven't really done any tune up yet besides the oil change spark plugs and wires. and fuel filter
Biggs2004
yeah a good tune up is good every now and then, There's a cool dude that does it here, Steve's Computerized Tune-up, he's awesome... anyway if there is anything wrong with your car they can tell you..... if it's not internal. It's a good place to start anyway. tune-ups around here run about $60.... Good Luck
skazzi
Car: Sports, Art, Music, Movies, Life!
Hey there. Where are you located and how cold is cold?
I had some troubles starting & stalling and discovered it to be my battery. Not enough CCA specifically. Once it did get started and stumbled to start, it would run perfect. I think the minimum CCA's you need is 440 (Nissan specs for an 89), I had 460, NOT enough as my car is fully loaded and it's freezing!
Best of luck.
GuSpeed
Skazzi i think you solved my problem. Well I haven't got a new battery yet. But in the morning when the key is in and about to start every start curcit and powers out. Wait a second try again and it goes out again a few tries power back on. It was in the 20s here and now maybe 30 or low 40s. Is this the battery? If so what kind of battery should I purchase?
skazzi
HiI can only pass along my experience, I'm not sure if it's your battery or if it's not though it does sound like it if my opinion counts for anything. =o) If you are able you can bring it in for testing too.
On the top of my old battery there was a sticker indicating the number of Cold Cranking Amps that it had, for me 460. Also a little eye for reading the status of it. Green for good and dark for needed to be charged to be tested. For the first while it would crank but take a while to turn over. The colder it got, the longer it took. Eventually, this past week (which did dip down to about -10C, probably around 20F) it would only click and die and dim the lights as I tried to turn on the power, also set my alarm to a faint whine. It would not consider starting. Also found that the longer the car sat such as when i left for work in the afternoons it would be tough to start too.
I posted a thread for help about batteries and some great folk helped me out with a few symptoms. http://www.nissaninfiniticlub....46527
Nissan had three options listed for my 240sx ranging from. 440 - 660 CCA I bought a Interstate Battery with 800 CCA for $100, my car has started up great since and a bum battery was for sure my problem.
Have read on a couple of the forums that Optima & Delco are good batteries.
Hope this helps some, best of luck!
Biggs2004
I've just got a continental Terminator battery, it's throwin 1,000 Cold Cranking Amps, it's brand new, and I've still got the problem. Some times, not all the time, only when it wants to.
Biggs2004
Well, I'm getting my cold start problems fixed, I've found the solution!...........I'm getting a new engine.......... :rolleyes :D
