SullivanRacing06 »
https://forums.nicoclub.com/sullivanracing06-u63212.html
Mon Jan 26, 2009 12:49 pm
the carrier is located under you car, the driveshaft is held in it, there are two either 14 or 17mm bolts holding it in, to remove the driveshaftb undo the 4 14mm bolts holding the driveshaft to the rear end and undo the carrier bolts, then pull hte driveshaft out of the rear of the transmission
