Carriar Bearing/ Driveshaft support
Dereek
Does anyone know where i can get one of these cheap? The only price i can find it $150 for a bearing. Is it better to just save $100 more and get the straight driveshaft
Does the front half or the driveshaft from an automatic 2+2 fit the front half of the driveshaft of a N/A 2 seater?
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
I would spend the money and buy a 1 piece. Not very long ago my brother replaced the center bearing on his N/A. It had a real slight vibration at about 45 mph, so he thought he'd change it. Bought the bearing and we installed it. Everything was clocked as it was before, and once the new bearing was installed, it vibrated like a bent drive shaft.After inspecting the u-joints, they were a bit lumpy when they were moved by hand, as if they wore in as the shaft on these cars does not go up and down due to the rear axle has a fixed carrier. No other real explanation.When I had my DS off earlier this year it felt a bit the same, but it doesn't vibrate at all.So, after all that, he takes the shaft in, gets new u-joints installed and both shafts balanced at a drive line shop. Totally undriveable now due to vibrations, so a 1 piece will go in. Even the reputable drive line shop has no idea what's wrong. Completely balanced shaft assemblies, new center bearing. Several hundred dollars of wasted money.
shortmag
Car: 92 300zx n/a
I just swapped out to a one-piece about two weeks ago. my carrier bearing was trashed as well. i figured why not eliminate the need for a carrier bearing all together...
see my thread here:zer...wpics
SM
Dereek
Yeah thats what i figured too, since the stupid piece is alreay $150.
but do you know if the front half of a driveshaft from an automatic will work. The carrier bearing on it is good and i would just swap the front part of it. might as well use what i have instead of buying anything right? im not wasting anymoney this way. Just time and labor.
Zwicked
I'm pretty sure the front yoke is different size/spline so I doubt it
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
buynissanparts.com I think had them for abour $110 IIRC
Dereek
Zwicked wrote:I'm pretty sure the front yoke is different size/spline so I doubt it
yeah i knew that that part was different, but i was going to change it from the u joint. Is it still different? I just dont want to do all the work to find out that it wont fit.
Modified by Dereek at 12:03 PM 8/29/2008
LAKE ERIE Z32
Car: 90 Nissan 2+0 300zx TT, 13 ford taurus SHO (TT AWD)
get the one peice made for your car you wont regret it
