Cargo Weight.
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
jungerfrosch
Car: 1965 Datsun L320
I just picked up a '65 320.
I see in the manual there are three different cargo weight capacities, U, UN, and UP. How do you tell which one it is? In the manual I see there were different trans and axle ratios, and different springs and wheels.....is this the only way to tell or is it labeled somewhere?
My truck seems to be a UP, based on the spring configuration and the very old 600-14 tires, I haven't checked axle ratio yet. Springs and obviously tires can be changed though. I can't even imagine putting 2000lb in my truck though.
Tad
ohreally21
Check VIN on car, trans, engine..etc. That should lead you in somewhat of a correct direction.
dp320
Car: 1965 520
Hey! Original bumpers! Funny added hood ornament.
Does it currently run?
difrangia
Car: 1978 Datsun 620 'Longbed', 1964 NL320, 1961 FIAT 500D, 1964 Type 113 Beetle, 79 Ford Festiva
Jungerfrosch,
Congratulations. Neat old survivor '65. Should you ever change your wheels/wheelcovers, and consider parting with the hubcaps, I'd appreciate a shot at them.
Steve
jungerfrosch
No, it's currently not running, the engine is free though and I'm hopeful that it won't take much.
I'm planning on keeping it stock so I will be keeping the hubcaps, sorry. I was actually wanting to find some replacements as a couple of them are rusted through in spots...but from what I've seen It looks like I will be repairing them.
Tad
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
jungerfrosch,
First welcome aboard! Truck looks nice. My one '65 had some aftermarket greyhound hood ornament from a Ford or Lincoln that was properly removed and then ceremoniously smashed with a sledgehammer and ran over a few times.
A few weekends and you'll have it running. Their pretty simple to work on and contrary to some parts are available. You just have to know where to look and what's compatible from other models.
Weight capacity - that's a good question. I have several little 320 and each one has a different spring count, difference in spring thickness and bump stop bolted to the frame. Somewhere I read the difference, let me do some digging.
In the mean time let us know if you need any assistance.
cheers,
Li'l Truckie
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
jungerfrosch,
Found the Spring thickness and count to answer your question. So here is a couple of screen captures from the 320 Service Manual put into a jpeg for you -
enjoy
Andy
jungerfrosch
So then the only difference are those things mentioned in the manuals; tire size, rear spring configuration, and trans and rear axle ratios?
The frame, axle and front suspension are all the same.
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
That's my understanding.
I'll snap some photos of my springs with a mm ruler and post later this evening as I have a few different combinations.
But seriously, a little 320 hauling 2000lbs of cargo, I can't imagine :rolleyes:
Andy
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Well here's a combo photo of my 320 rear leaf springs.
Should be easy to ID the 320-U with only three leaf springs.
But as for the UN and UP, I probably should have taken better pictures and pulled out the micrometer and measure each leaf spring. Without a doubt the bottom spring is 12mm. However, the other four are a little to close to call in these photos. I'm guessing these are all the UN with each spring at 4mm as I do not know what the rubber helper is?????
Should the rubber helper not be on the leaf spring assembly or is the manual mean the top bump stops? No idea at this time.
cheers,
Li'l Truckie
Single pic can be found here on flickr-
https://www.flickr.com/photos/113742723 ... 618912532/
jungerfrosch
Here is a picture of my rear springs. I rotated it and cropped it so that it would be easier to read the measurements. This is just ahead of the axle on the drivers side. It looks like 1 12mm, 2 6mm, and 2 5mm to me. I think it is interesting that the UN actually has heavier springs than the UP, unless they are somehow different other wise.
Is this the same as what your trucks have, or is this the "helper rubber" they refer to?
Tad
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Tad,
I have the same rubber bump stop on the one I think has the thicker 5mm and 6mm springs. So is this the rubber helper the manual is talking about? I'll check the manuals again.
Just a heads up. This rubber bump stop makes bleeding the rear brakes a pain in the butt. I finally just cut a 7/16 wrench down to size for this job.
v/r
Andy
Return to “Datsun 320”
