CARGO VOLUME
Crazy Jake
Car: 2009 Nissan Rogue SL, Venom Red, Leather, Moonroof
Cargow/2nd row seat upright - 28.9 CU FTw/2nd row seat folded down - 57.9 CU FT
The specs list the above. Can anyone tell me if this is deck to underside of cargo cover or dect to ceiling/window?
philipa_240sx
In a nutshell, it's from the cargo area floor to the top of the seat back... including the headrests. The ceiling, window sill, or cargo cover is irrelevant.
When the rear seat is folded, the height is the dimensions from the cargo area floor and/or folded seatback to the top of the front seat headrests. The length is from the front seat back to the hatchback door.
The dimensions are calculated according to SAE standard J1100. It's very technical and all automakers have to adhere to it when reporting dimensions, volumes, etc. Figures from different automakers should be directly comparable.
In the case of the Rogue, the rough cargo are dimensions are:
Rear seat up: 30"H x 50"W x 32"DRear Seat down: 28"H x 50"W x 68"DFYI: The rear door opening is less than 48" wide.
Return to “Rogue Forum”
