datsun5ten »
https://forums.nicoclub.com/datsun5ten-u23873.html
Fri Nov 27, 2009 5:35 pm
Run a run megajolt box, Coil pack, EDIS Ignition module, VR sensor, 36-1 wheel. like a crank trigger? humm
Ya i read that thing to .. the engine ( vg30s) was in like a truck, over in new zeland. some one also said saidi arabia.**** ( sorry i cant spell for shhhit)
I tried and tried to get ahold of that distributer, because it will do every thing we need.. great! but.. my 2 contacts in New zeland had no luck getting through any where with nissan, and the only people that have ANY kind of communication with getting any or having them made again..is the vg30.com guys in Washington. any whoooo.. i got screwed by some fool on ebay that told me he had a vg30e dist with pick up.. i fell for it for 250.00 and the prick sent me a OEM distributer and fell off the face of the earth. soooo i got a magnetic pick up.. by protronics.. i can get the P/n if you want it. It running to a MSD box that i was told would work for what i wanted.. on the back of my MSD box.. there is a port for a piggy back. the module you can buy for the msd box.. will allow you to set redline, advance timing, ect. ect... another 250.00 if i remember right.. I have my VG set around 29* right now.. because i was running it on the street a lot.. if i bump it up in the 30's it will pull all the wayyyy. I only took it up to like 7200 then shifted but it did a dam fine job.. suprized me..scared me too.. engine sounded like a bat out of hell. With it set around 29* its really torquy from like 2k to 5-6 but it feels boggier up high.. Since i have been running it lock down i have had no problems.. but With my new build currently under way.. i am adding the spray.. and will need to retard timing when on the juice.. or. find my sweet spot for the track ( 32*ish) and retard it accordingly from there and lock her down, so when the n2o is acctivated it is mathced up. I love this engine carbed.. dont have to deal with having the ECU flashed..or injector duty cycle.. MAF's. o2 sesors, ect ect ect. I just turn my fuel up on the carb and let her suck as much air as she wants. do you have any pictures of your cars/swaps?
