xsdg »
https://forums.nicoclub.com/xsdg-u227699.html
Sun Dec 01, 2013 11:14 pm
As for the age, the correct month and year of manufacture should be listed in the driver-side door jamb. Of course, if there were an engine swap at some point, then that might not accurately represent the age of your motor.
Yeah, if the ECM is gone, that means that the anti-dieseling solenoid is either disabled or broken — the no-power state of the anti-dieseling solenoid is to cut fuel, so if the truck fires at all without the ECM, then that's not working properly.
That said, it should be possible to tune the carb to run at least okay without the ECM in place — the truck will run in open-loop mode during vehicle warmup anyway, and if the ECM is missing, the A/F solenoid shouldn't be getting any power.
One thing to note, though, is that the choke may never open if the choke heater circuit isn't getting power (which I would expect, given the missing ECM). In that case, the truck may be running lean once warmed up because it's choked. Open the air cleaner with the truck running and check the passenger-side barrel of the carb. The choke valve is at the top of that barrel, and if it's not in the completely-vertical orientation after a couple minutes of warmup, then that's a big problem, and will cause the carb to run _way_ lean in open-loop mode.
