frapjap wrote:Welcome to NICO!
That sounds like a pretty cool idea for a build. What type of car are you planning on putting it into? Or is it just a conversion? Does your state bust your balls with inspection (if you even have it?)
I've got nothin' in regards to advice, but would be thrilled to see what you do with it on a build thread when you get it together!
Thanks! ( now the forum let me sign back in) I've got a long way to go. I've been looking at other engine set ups and think I found a "starting point". I wish I understood more of the wiring and electronics part to dissect it. I seen a wiring set up for the ford 4.6 dohc engines to swap it to carb, but it comes with a sensor or 2 that I'm not sure would relate to the vh45de. I'm trying to figure out "on paper" before I start spending money on electrical stuff. I think the wiring system was once again a MSD set up. How would I go about measuring the sensors and wiring conversion to make sure it would match up circuit wise? As in I probably would clip off one side of the plugs (engine/conversion wiring) then splice in other plugs (from original sensors/ford 4.6 wiring harness etc) to make it a plug and play .
I tried to find some sort of data sheet that would give me an idea of how to test everything to make sure that the sensors were working properly so I know if I could match up the resistance (?) Of the sensors to the spliced in msd donor system.
I hope this makes sense. If a wiring/tuner/electronics guy can throw me a bone I would appreciate it. Maybe my figuring sparks an idea in some of you... if so then by all means have at it and share the info.
I'm not sure what I want to put a vh in yet. I'm more worried about firguring out the wiring/carb problem before I start trying to buy a vh so it's not sitting in yard long waiting on me LOL.
Any thoughts are appreciated
