carbon removal.... could i of messed something up?
rivetapproved240
Car: mechanical work
heres what i did. i took 1 bottle of seafoam, but 1/3 through the intake , 1/3 through the brake booster, and 1/3 in the crank case, with the car off. I then removed all of the spark plugs and wires and sprayed a 4 sec spray of seafoam deep creep directly onto the piston crowns. i let it sit for about 1 hour (heavy carbon due to bosch +4 ), covered sparkplug holes with towel and dry cranked to remove excess . reinstalled plugs (new) and new wires. held throttle at wot and turned ignition... car cranked and i held it at 3k rpm's for about 1-2 mins... Heavy smoke dark in color, not the usual white smoke... it was kinda gray but not black. drove car around block to get excess off. changing oil within next 20 miles. car runs great but i was wondering if i did this wrong, this was explained to me by a friend of mine that is a mechanic but i dont know if i followed the directions correctly.. the car runs absolutly great....
fantabulous
Car: s14
if the car runs absolutely great, how could u have messed something up. isnt that the point?
navysnail
yep, thats right. you might want to go ahead and change the o2 sensor also, as all that carbon will have given it a nice coating
xekushnr
Car: '90 Nissan 240SX Hatch
man, i really gotta get some of this stuff. do autozone or murrays sell it?
rivetapproved240
advance auto parts and autozone sells it... but i have only seen one autozone that sells the deep creep. anyways... i was wondering if the pressure due to the liquid being in the cylinders and the pressure from the intake could cause something like hydro lock? perhaps i just got lucky
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
No, you're fine.
navysnail
since you took your spark plugs out, there is no way it could hydrolock, it doesnt make any pressure like that
Axel Grungy
Car: 2001 G20 5spd
xekushnr wrote:man, i really gotta get some of this stuff. do autozone or murrays sell it?
the murrays down here sells seafoam, i actually found some at one autozone as well.
