Tr0uble »
https://forums.nicoclub.com/tr0uble-u50780.html
Fri Nov 17, 2006 7:55 pm
No its not leaking at the seals. Rainwater is supposed to flow into the sunroof, flow into the drain holes located at the 4 corners of the sunroof, then flow down the drain tubes and drain into the rocker panels.
1 driver side front drain tube, 1 driver side rear tube, 1 passenger side front tube, 1 passenger side rear tube.
After the water flows into the rocker panels it's "suppose to" go out the rocker panel drains. Driver side works as designed. If I pour water into the top of my sunroof on the driver side it drains in the tubes to the rocker panel and then can be seen flowing out from under the car.
My problem- when water enters the passenger side the water drains down the tubes into the rocker panel and stays there. The level in the rocker rises to the screw and drain holes and floods my passenger side floorboard. When i first noticed the problem I had 2+ gallons of water standing in the passenger floorboard. Hit the brakes when i heard water and it almost flooded my ecu (phew!).
I've looked under the car for the drain holes on the passenger side and can't seem to locate them. In my opinion designing sunroof drains with the ability to flood the floorboard for the 240 is one of the worst ideas I've ever seen. As i've said there are pics on the net of people with the same problem where they let it go to the point of their rocker panels rusting and rotting out the sideskirts and part of the fenderwell.
I could care less about my sunroof. If someone sold a carbon fiber piece (sunroof plug) I'd use it in a heartbeat. Superstreet featured a 240 with one from a place called Racepods.com, but the site seems to not exist? If someone knows of a place that makes and sells what I'm looking for please help me. If not for me for the sake of a 240.
