livinglegend2100 »
https://forums.nicoclub.com/livinglegend2100-u88812.html
Mon Mar 30, 2009 6:42 pm
ive been dealing with this for the past year or so. once you figure it out, its second nature. and dont slam it. because you'll chip the resin and end up wearing the hood as a hat down the freeway.
first off, alignment was a slight issue for me, i had to bend my hood latch towards the rad support about a 1/2 inch. maybe more or less for you. just eyeball it to figure it out.
after that i just set the hood down and once it clicked down into the "halfway point" i push down on the hood directly over the latch. and it close the rest of the way. and voila.
note: you may need to grease your latch assy for smoother operation. ive been running without hood pins for almost a year and ive had no problems. no signs of cracking or anything around the latch
