madmax88 »
https://forums.nicoclub.com/madmax88-u4744.html
Mon Apr 07, 2003 5:08 pm
CARBON FIBER DRIVESHAFT, 90 300ZX NA 2+2 A/T will this fit the J30 . and how about flywheel 300zx With reduced weight (stock 21 lbs., this beauty weighs in at just 12.5 lbs.), less power is needed to overcome flywheel inertia. The result is a quicker revving motor. The stock flywheel is essentially the automatic's torque converter plate with weights added and is not ideally suited for performance applications. Uses the factory timing ring/gear from the stock unit. Actual product
