Carbon Fiber Driveshaft for G
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
Sup, I found this site that makes em, but not sure about G's
http://www.acpt.com/driveshaft/index.html
anyone know where I can find one? Or if anyone is even making them other than custom?
Just curious....
I've already got a pulley/crank kit and a LW flywheel and she rev's crazy fast as it is....but a CF Driveshaft would just be that much better! and better power transfer along with the weight reduction.
Anyone know a reason why I shouldn't upgrade to a lighter driveshaft.
Thanks.
joe603
Car: 2014 Durango R/T
....expense is the only one I can think of. They will handle more power and not vibrate at all. Do a driveshaft loop while you're under there.
How 'bout some pics of your mods!
USAF_G35_Guy
Does anyone make a one-piece CF driveshaft? Or do I gotta stick with the 2-piece. Why is it a 2-piece anyways? Just the angle I'm assuming?
Either way....If they make one, I wanna do it
Less vibration (not that there's really alot in the first place that I can actually "feel") and better power xfer/throttle response would just be sweet!
I'll see if I got any pics layin around...
USAF_G35_Guy
Here's a few pics for ya Joe.
zerothread/297818
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Usually 2 piece shafts are because of length or angle. With carbon fiber I bet its cost. Probably a whole lot cheaper to make two short carbon fiber shafts and put a joint in the middle then to make one long shaft and try to balance it.
The Ram had an one piece aluminum drive shaft.
