USAF_G35_Guy »
https://forums.nicoclub.com/usaf-g35-guy-u72189.html
Mon Feb 18, 2008 11:47 pm
CF is one of those things that's all about personal preference as far as looks go, but if you're turbo'n your G it sounds like you're semi serious about putting a few track days in the near future. As far as doors go? I'm not sure if you can keep your stock interior on them. Especially when it comes to.....are there factory spec'd mounts/holes for your power window assembly. The best thing to do is just ask the people who make the doors. As far as the actual panels go, I would say you could make them fit even if they weren't designed too. The top lip of the panels will probably still lay in place (if the car is designed to even have a window and not pure race) and then you'd just have to worry about actually securing the panel to the door, but most of the weight is held on the top rim. Either way, I'm not sure if dropping weight between the wheels is as important as just dropping it from the front end, as CF hood/fenders/front bumber would probably give you the best 50/50 front/rear weight balance. Especially if you're adding a turbo and piping to the front end, you'd probably wanna drop most of your weight from the front and leave the middle/rear as is. Just my .02 tho Of course you could just CF everything except the unibody, strip the whole car bare, and then just tune your suspension for the optimum setup! Either way...good luck! and pics when you're done!!!! BTW, I also have a CF hood and have also considered CF fenders and front bumper. The only reason I haven't tho is cause I don't wanna look too ricey If my car was black I probably would, but it's Grafite and as I'd personally like it, I'm not a fan of getting all those...WTF looks and WTH did you do that to a G35 for!
