okay, so I was looking at my carbon canister and notice it has 4 lines coming from it and most people only seem to know where 2 of them go. So I was thinking I would just remove it but while searching and trying to find more info I came across a Z forum post where the guy had deleted his, then made a new one, only this new one looks a lot better, isn't in the way of anything, and it a much simpler setup(2 lines).
So I though I'd just copy his setup, which is use a stainless water bottle, make 2 ports in it and connect one to the hardline going to the gas tank and the other to the intake mani(as per the write up). Then it hit me: I bet the extra lines on mine are to control some type of valve so the boost in the manifold doesn't pressurize the gas tank....
I still want to change the can to the new one, as this can is good for the environment and doesn't effect performance(as long as I can move it that is). I could rig up a new mount or something for the stock one but I really like the idea of a stainless can with new carbon in it also.
So heres the question; am I right about the extra lines being for valve control to not pressurize the gas tank, and if so couldn't I just use a one-way valve(like a pcv valve) between the can and the manifold to make it work? I was also thinking I could hook it up to the intake before the turbo as that always has vacuum, but running gas fumes through the turbo might not be a good idea.
