Carbon can change
Second Shadow
Car: 93' 240sx, s13 blacktop sr20det
I'm planning to do the massively oversized IC behind the radiator core support thing, and the pipes have to go past where the stock carbon can goes so it had to be moved. Also it had like 4 hoses coming off it and people only seemed to know where 2 of them were supposed to go.
so in the process of searching and trying to figure the thing out I came across this thread in a Z forum.
zer...59832
seemed like a good idea and allowed me to move the can and make it look better at the same time. However the strait through design of it means in a turbo(mine is s13 blacktop sr20det) it would pressurize the gas tank under boost, and would require additional valving(prob what all the hoses on the stocker are for). So what I came with was a pcv valve on the exit of the can.
now funny thing, it worked at first but after I shook it some carbon got stuck in the valve and it wouldn't close sometimes. you can shake it again and it would work, but I didn't want to hit like a bump or something and suddenly have a pressurized gas tank, so i added another check valve between the pcv valve and the vacuum hose going to the intake. anyway heres how it turned out. not a big deal but a nice weekend project I think.
old can
new can before install
Installed.
Shabbernigdo
why not just remove the carbon canister all togeathere? its much easier.
Kalypso
i suppose, because this is more fun.
Second Shadow
if you remove it all together then gas vapors escape through the hardline. this is bad for the environment and it violates emissions in most places. if you don't care about that then removing it isn't a big deal, but I do.
ZOMG.SR20
Car: 1990 s13
Second Shadow wrote:if you remove it all together then gas vapors escape through the hardline. this is bad for the environment and it violates emissions in most places. if you don't care about that then removing it isn't a big deal, but I do.
You have a SR and care about the environment that has to be an Oxymoron
Second Shadow
I care enough to not have an unnecessary gas vapor leak. It doesn't effect performance so what's the problem with it?
Black on Gold
Since when is having an SR less environmentally friendly then any other motor?
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
your thermos wont pass emissions testing anywhere.
have fun
ZOMG.SR20
Car: 1990 s13
It doesnt have Any or as many as the stock KA and Most people that have SRs run retardedly Rich and alot of boost
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
I like the small can idea. The last owner left mine open. Also, I cut up a NISMO test pipe to weld a catalytic converter in... Rewelded the name plate to the cat too.
Second Shadow
mrgreeneyes wrote:your thermos wont pass emissions testing anywhere.
have fun
actually yes it will. the rules in my state are basically, if "one" came with the car, it needs to be on the car. which means if the car came with "a" carbon can, it needs to have one. doesn't have to be stock, just needs to be there. you can run a full race 5" cat if you want, all the rules say is a cat needs to be there.
There's only a safety which has a visual emissions test anyway, and they don't care so much about that sort of thing. mostly if your ball joints and break pads are good so you don't crash, you pass.
besides, I can take the lid off and show them it's full of carbon if they want, just to prove it's legit. and the car won't smell like gas either.
PS: I do have the stock one just in case, but I'd bet real money it never comes up.
StandardProspect
Car: '93 Nissan 240SX
'98 Infiniti Q45
Ive got that same water bottle. Its awesome and i take it everywhere i go. Why did you destroy yours?
Second Shadow
......I bought it just for this. never used it for drinking.
