nisstek »
https://forums.nicoclub.com/nisstek-u4058.html
Thu Feb 06, 2003 2:24 pm
Higher than normal cylinder pressures can only be caused by carbon biuld up. I would run Top Engine Cleaner through it to remove the carbon. Injector cleaner wont work and I dont know anything about the Seafoam products. When running the top engine cleaner through the engine rods can be bent if done incorrectly. Not for the faint of heart. You are effectively running a liquid into the cylinders with the engine running. Be careful!!
