Carbon build up on Cylinder #4 of 1993 240SX
justjuiceit4
Car: 1993 Nissan 240SXs, (Coupe and Convertible) 1994 Infiniti Q45
I have a KA24DE and the other day I was changing out my sparkplugs. They all had a nice tan color to them. I decided to check out to see how my pistons were. #1,2 and 3 were all perfectly clean, but #4 had some carbon build-up. I checked it with my compression tester and sure enough it had more compression.
Now the plugs gave no idication of oil fouling and it did not look like any oil was leaking in there. However, I did notice the last valve cover bolt was just sitting there and the top head had actually snapped.
What do you think caused this carbon build-up? Is seafoam the best way to get rid of it without pulling the head?
justjuiceit4
So nobody has any ideas?!
MaximA32
I would run some injector cleaner and see if it helps.
justjuiceit4
I do not think injector cleaner will really work to clean the carbon. My main concern is what caused the carbon build up!
