Carb question
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Would the dual side draft carbs on my S30 be able to be put on a 521 pickup if the pickup had a dual carb manifold?
Mr1der
if they fit on the manifold...probably so.
your car have the SU's on it?
NSR_s30
'71 Datsun 240Z
Yeah, Jerry and I were wondering if it'd work. Cause if I get rid of the duals for triples, I'd give the duals to use.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the 521 I assume has a L20B? yes you're L24 SU's will work but you'll need the propper L20B intake manifold, I think the trucks all came with downdraft carbs
NSR_s30
'71 Datsun 240Z
No the 521 has a L16, would it make any difference if it wasn' the L20?
S13Teddy
Car: R32 Skyline, S13
Wouldn't it be over-carburated then if you're using carbs from a 2400 on a 1600?
NSR_s30
'71 Datsun 240Z
I don't think so, plus the SU's are adjustable too.
S13Teddy
oh ok. gotcha. Because I know that the Mikunis from mine even when they were adjusted were still over carbed..
evildky
06 Nissan 350Z GT
my main point was that I know there are su manifolds availble for the L4 engines, the later CA's and KA's I don't think so, and yes you can get SU's in varying sizes as well but they tend to support a broader range then say webber DCOE's, tuning either is something of a clack art, the su's it comes down to filinf your needls, on DCOE's it comes down to propper chock, air bleed, and jet, this is why I run megasquirt, injection is so much simpler
back on point, the 2 su's should work ok on the L16, worst case scenario you could get some smaler SU's from an MG
NSR_s30
'71 Datsun 240Z
You da man. Thanks for all your help guys.
DemonZ
Car: 1972 240Z
evildky wrote: I think the trucks all came with downdraft carbs
I have a buddy here in town with a 70 Datsun Pickup, dont remember the model, but it had an L20 that had dual SU's on it.
Return to “Datsun Chat”
