carb problems!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
jdamion
Car: 1980 Datsun Pickup
so a few days ago my pickup starts to cut out and sputter, ran low on gas and it died, so i figured i ran out of gas, managed to get a half tank in it and replaced the fuel filter and a fuel line under the hood. and it continutes to sputter and die / cut out when i try to drive it, i think maybe the choke may be stuck open, could this be the problem?
i know i still need to sea foam it and rebuild the carb. but i just wanna do a quick fix untill i have enough saved up for a weber carb conversion. ( 2 weeks?)
any help will be nice. thanks in advance. the haynes manual isnt all that clear...
PEZi
try the vac lines before you assume the carb is bad... or possibly ignition stuff
i wouldn't say its specifically a carb problem itself as much as something around the carb... and if you plan on doing a conversion, a rebuild on the carb (which doesn't end well most of the time) is probably not worth your time or money
vac lines are cheap... start there
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
jdamion wrote:i know i still need to sea foam it but i just wanna do a quick fix
Sea foam is a quick fix. May be there is something lodged by the inlet valve limiting the supply of fuel, or your timing is out somewhat.
Return to “Datsun 720”
