Carburetor / brake parts needed
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
Gemmer
Car: 1964 Datsun PU 320
I am looking for;
Carburetor part # 16310-08103 or # 16036-08100 ( not sure which, it is the power bar jet for the Nikki carb 2D -30C-3 )
Thermal Transmitter part # 25250-30100
It's been 10 plus years since I have worked on my 320-PU. Need to do a complete brake re-build. What current master cylinder and wheel kits can I use?
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
Gemmer,
For Carburetor part # 16310-08103 or # 16036-08100 these are the Assembly-Jet, main air bleed primary and secondary. So do not know what the power bar jet is. Also, do not know where to purchase these seperately.
For the Thermal Transmitter 25250-30100 (AKA a thermostat) this is available from NAPA or eBay. Just watch the threads as one type is fine and the other is coarse.
Brakes are easy. Brake and Clutch rebuild kits are available on eBay or a complete unit order through your parts store, you will need to tell them its for a 311 Fairlady or 520. Look at picture first on their screen. Also make sure its SAE and not metric on the 520 for the brake line fitting. The brake MC is 3/4 bore and the clutch is at 5/8 in. All brake wheel cylinders are 3/4 inch bore. You can occassionally find the rear wheel cylinders complete for around $18-$25 on eBay. But I have only seen the front once or twice and I snagged them both times. 3/4 in front kits are available for the 620 on eBay, you just have to re-use your boot/cover as the one is the kit will not work.
Part number for the drums are 406 and 405 by BrakeBest and I think BorgWarner has the same number 406 and 405 or 406a and 405a. So no need to buy these on eBay.
v/r
Li'l Truckie
Gemmer
Lil Truckie;
Thanks for the info on the brakes and thermal transmitter.
Do you know of any source for carb jets?
Regards
Gemmer
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Gemmer,
Let me look and see if I have an extra. I recall that I did find one with my two 320's out of Montana. I'll also find the Nikki webpage I saved.
Andy
Return to “Datsun 320”
