carb info plz
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
jikei620
Car: 1975 datsun 620
i just bought a 1975 620 and it needs a new carb. i have an old dual 40mm weber carb and was just wondering if that would fit and work. if not what kind of carb should i get? n e info would help alot thanx
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Hi!
Welcome ..... your 40 will work if you have the right manifold.
jikei620
thanx. what kinda manifold do i need 2 get? can i get an adapter plate? would it b cheeper if i just got a 32/36 weber?
phlebmaster
You might be better off to check for an inexpensive Weber 32/36 but you will still need an adapter for your stock intake.
Look for both....compare the price if a single side draft intake with the price of a used Weber and adapter plate.
If you go with the Weber 32/36 then I recommend a high rise adapter. Google it and you will see what I am talking about.
Return to “Datsun 620”
