carb'd KA24DE
crazee240sx
Car: racing
Anyone converted to sidedrafts yet?
Here is my real question to every one. Im building a road race/autoX motor (91 240sx). The thing is because the car is so versitile I cant really go for an all out "road race" motor, because it wont suit my Auto X needs (this situation is visa versa). So, my question(s) are this:Consider Ive done the piston conversion into my DE1: can I run NO emissions, vaccum crap, IACC (or whatever) and still tune the vehicle to run a decent idle2: Will the PDM cams be mild enough to run with the piston change?3: Does the injectors on the KA run off of distributor impulse?4: Will a S-AFC suit my stoich tunablity needs, or do I HAVE to run a stand alone (FAST system)5:Will timing changes throw off the S13 ECU?6: How dependant is the engine of the ECU?
Im essentially trying to take the preprogramed settings out of the ECU, and leave them up to me. All I want the ECU to do is run the settings I tell it to, THATS IT. From previous experience with OBD 1 systems, Ive found when adjusting engine messurments, the computer will change them back to stock..IS this true with the S13 ECU?Thanks for your help in advance
EnzoRWD
Car: 1997 Volvo 850 T5
well SAFC wont run carbs. but u already knew that. so im an idiot.piston coversion = sohc pistons?
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
ill take this oppertunity to post some pictures from my collections
deviousKA
post whore
nismofan14
Nice pics. Who's car is in the first pic?
deviousKA
that first pic is a 510 owned by twistex, he sometimes surfs the boards. The second is an unknown 510.
only comment i have on ka24de carb conversion, try to use an altima intake manifold, it is not quite as steep of an angle.
