Carb Adapter Plate for SR20DE q's
totoro001
Car: Changes Constantly
Would anyone know of, or has anyone heard of a place that makes a Carburator adapter plate for the SR20DE? I could have one made but i'd be looking around.. well.. a sh*tton of money so i'm curious if anyone's ever heard of one bieng manufactured.
and please don't give me any responces like "omfg carbs you = stupid blah blah".. :P
Lucian_rider
Car: Silvia S13 Fastback with SR20DET
I believe there is a bit more to it than fitting a carb onto a fuel injected manifold.
The runners are much longer with EFI and this will cause problems with fuel condensing onto the inside walls which could cause all sorts of jetting problems.
I was thinking of doing the same thing with a KA engine that I was installing in a carburetted pick-up. Eventually I gave up the idea and spent a **** load of money on getting the EFI to work. I don't regret the decision.
I'm sure you could probably get it to work but whether you will be happy with the performance is another question.
Chris
totoro001
oh yeh, i'm aware there's a lot more to it than just a mani and slapping on some carbs, but i figure it'd be a good place to start since it's a rather essential part of the whole system if there aren't any in existance yet, i might just go out and have some made, oooor try something different all together.. just trying to see if it's been done yet
s13sr20chris
never heard of anyone carbing a sr20. i imagine it would be kind of difficult because the intake ports are not a flat surface(allowing two two barrel carbs). you might be best off building a short straigh tunnell ram style manifold with a forward mounted four barrel.
