480sx »
https://forums.nicoclub.com/480sx-u50548.html
Fri May 04, 2007 5:07 pm
Those marks on the chain itself will rarely line up with the corresponding marks on the cam sprockets, and the idler pulley. You can however turn it over by hand until they line up(or dont, if you have your cam timing off).
You will need to take off your upper timing chain cover to do this. On the idler pulley itself there is a mark, and at TDC it will be at the bottom right hand side of the idler pulley. Its a little indentation on the idler pulley. Set the gold mark on your chain to line up with the center of this mark. Next, bolt your timing chain guides back up, so that you cant move the chain while its resting there.
After that, line up the silver marks on the chain with the little dots on your sprockets. You will need an adjustable wrench to move the cams into the correct spot, so the sprocket will go up on the cams. IMO, its easier to do it this way than to guess at what 10 o clock and 12 looks like. Plus you have the satisfaction of knowing its done right.
So you say your not getting spark? I have no idea what you mean by the moldings inside the cap are broken. Disregard the posts about your cam timing until you fix your spark issue. You are grounding the spark plugs when you are testing them right? A picture of what your talking about in regards to the cap would help.
