nope...i might just see if i buy one from an autoparts store and find out its not the MAF see about returning it.Ender_Zero wrote:I'm with biggie, sounds like you should try a different MAF as the first troubleshooting part replacement. Got any friends with 240's you could borrow one from?
Open loop always reads cts, tps and maf. Closed loop reads all sensors.mastakilla08 wrote:Correct me if im wrong, but when the car is cold it starts in open loop mode, so really it is not utilizing the MAF until it hits operating temp? so it couldn't be a bad sensor and also would it not shoot a code??
I've only replaced plugs, plug wires, maf, and thermostat. Would you happen to know what the specs are on the coil? I can break my ohm meter out and check it.mastakilla08 wrote:sounds like ignition possibly your coil try testing it, have you replaced your intake or anything as well?
