udunnawme wrote:well apparently the two fuel lines going into the fuel rail where on wrong and needed to be switched. so i did that, and then it wouldnt start at all. so if someone could verify, the line with the fuel filter goes in the end of the fuel rail w/o the regulator, right?
and this is the sohc btw, if it matters.
Your statement doesn't make sense. From your first post, you said the car never ran. Now you're saying when you switched the fuel lines, it won't start. Which is it?
BTW, the supply line from the fuel filter goes to the front of the fuel rail. The FPR bolts on to the rail in the back and the fuel return line connects to it.
