sidewards wrote:thanks, The brake light goes out when the ebrake isn't engaged, like it should. All the other dash lights stay on even when the key is not in the ignition
When the E-Brake is down the Brake light should be out. Check the Brake master see if it is low on fluid that will make the light stay on also but nt without the key. Unhook the negitive battery and then hit the brake pedel for 5 sec this will use any remaining power in the ECU and then rehook the battery back up and see what happens.
There was a car in the shop the other day because the starter shorted out causing it to shut off and not start but u smelt burning wires check all fueses and see if there is a pinched wire somewere
Try the fuse first then the jumper wire. make sure the car is in neutral and the parking brake UP!!!!! or it will jump on you
