Florida240sx wrote:Starter going bad, Or maybe the switch on the pedal.
He said its a convertible with a auto to 5spd conversion so there's no switch at the pedal.
1. Check Battery Voltage. When the car wouldn't start and made no sound at all did you have power to the rest of the car?If battery voltage low, open the 2 covers on the battery and fill with distilled water if low.
2. If battery voltage is fine, get an ohm meter and ohm it from intake manifold to negative battery terminal. If greater than 1 ohm you have corroded grounds. Replace or make new ground wires.
3. Check condition of shift interlock bypass to assure its connected properly.
If there's an autozone or some kind of parts store in your area have the alternator checked.
Most likely its a bad battery since you said it didnt make a sound. Even with a bad starter you will hear a clicking sound.Most of the time simply refilling the battery with distilled water makes it like new again. The hill probably tilted the fluid in the battery away from the lead posts.
One time I had a bad ground and I couldn't start the car by rolling it. So if anyone ever tries to roll start their car and it doesn't work it may be a ground wire.
